Hi I am just wiring last bits on my car and a mate has come to help but he has just said about the pipe I am useing on my actuator he thinks they won't work propely I have used slicone brether pipe I used on my dump valve not the pipe you get with actuator but the pipe that come with it is a lot thicker which is the one he said use what pipes should I use ? :harhar:
use the pipe that come,s with the actuator its a lot stronger if you look a the hks bit of pipe it
will have treaded cotton for strength :lol:
will have treaded cotton for strength :wacko:
The only thing is been looking at it and the pipe that comes with is to sort for were fit to my boost controller is I would have to reroute all of it that would be a pain will the ones I have not be ok then
