chr15_7_t_ Posted October 27, 2009 Posted October 27, 2009 some of yous might know that the big ends went ..i drove the car for about 1.5miles after i started hearing the faint noise that did get worse. so i dont know how bad it is yet if im honest.but what all would you's think i would need to rebuild the bottom end of my 4efte? Quote
Steve GT Posted October 27, 2009 Posted October 27, 2009 if it was me id do shells, big ends conrods etc and that should solve the problem dude if it isnt that bad you might just get away with new shells and big ends Quote
chr15_7_t_ Posted October 27, 2009 Author Posted October 27, 2009 what could be wrong with the con rods? you think the crank will be ok? Quote
Steve GT Posted October 27, 2009 Posted October 27, 2009 should be aslong as you didnt thrash the crap out of it when you heared the bottom end was knocking then im pretty sure the crank will be ok dude Quote
chr15_7_t_ Posted October 27, 2009 Author Posted October 27, 2009 any idea at all how much this could cost me for thrust,main and big end bearings...and if i need anything els? Quote
RobSR Posted November 7, 2009 Posted November 7, 2009 bought 100 quid for a full set of standard bearings...but if youve been driving it knocking, 9/10 times youll need a crank grind, and undersize bearings which are quite i bit more expensive from memory Quote
