Hello,
I have a problem with my car..
I have a Starlet EP91 with a 4EFTE engine in side..
A sort of Glanza wink.gif I bought it this way and it works till now..
The Problem :
When I drive in second gear at 2K and then puch it to full throttle.. then it holds back very hard.. it takes 0,2 bar and builds slowly rpm.. and when itâ??s comes at 5K then it goes good..
And the Turbo pressure is 0,5 or 0,6..
When the car holds back it Stuttered..
What I have tried :
Turbo Map Sensor
Vacum hosses
Replaced Turbo
Replaced Mani
Checked Distributor Cap & Rotor Arm
Checked Fuel (thought I put the wrong fuel in the car)
I hope some one can help me with this problem ???
Greetings,
Jeroen
also worth noting is replacing your ignition leads,
i go through about a set a year.
the ignition system in general on the starlets are pretty week.
sounds to me as the boys above said ignition new plugs and leads sounds like a good idea. get some magnecore leads. there thicker and also look rather sexual and get some ngk iridium 8's is my reccomendation. run my car on them and its aweosme lol
Why NGK iridium 8 ? and not 7 ?
Standard is 6 right ?? so i tought i would get 7 ?
A set a year?? how does one manage that? :thumbsup:
30k+ anual milage every year should do it.
Yes here is the video with the camera..
www.youtube.com/watch?v=JjaZYBHClKQ
You must just lissen to the engine..
definatly sounds ingnition related,
you could be shearching in vain if you dont find the right cause so work mythodicaly.
take the plugs out and see if they need regapped or replaced,
if the plugs are fine work back until you get to the distributer cap.
dont worry though its nothing bad,
as we are coming into the colder months they take a beating.
  • 2 weeks later...
The Car will be checkt at it next week by a friend.. and iff that doesn't work it goods to a pro..
I'm just looking iff some one had had it ones.. and maybe solved it..
Diagnostics check done that yesterday and it gives no error..
But the car is standing still know..
iff i start it know it runs normal and iff i do some gas then the engine stutters and it don't come forward..
