Steve GT Posted November 22, 2009 Posted November 22, 2009 as the title says really where is the main fuse or is there one?or any locations of other important fuses apart from the ones in the black box near the battery or the ones un the drivers footwellany help is appreciatedcheers guys Quote
Dave@TM-Developments.com Posted November 22, 2009 Posted November 22, 2009 In the main fuse box under the bonnet, much bigger than a normal fuse Quote
Steve GT Posted November 22, 2009 Author Posted November 22, 2009 is the main fuse box the one near the battety in the black box with the starter fuse, AC fuse etc? Quote
Steve GT Posted November 22, 2009 Author Posted November 22, 2009 damm it I've checked them all and they look okk cant work out what the problem is lol Quote
andy.i Posted November 22, 2009 Posted November 22, 2009 might look ok, but check them with a multimeter Quote
Dave@TM-Developments.com Posted November 22, 2009 Posted November 22, 2009 Have you checked these ones? Quote
Steve GT Posted November 22, 2009 Author Posted November 22, 2009 yep all checked cant work it out whats up with it lol cheers anyway guysanyone else have any ideas where fuses could be that will stop the engine starting? Quote
Guest dominodon Posted November 22, 2009 Posted November 22, 2009 first thing first.. does the car crank over have you check if your geting a spark, and have you check if fuel is going to the engine. ? Quote
Steve GT Posted November 22, 2009 Author Posted November 22, 2009 fuel pump is working you can hear it when you turn the key but the engine wont even try turning over. you know like if a batterys dead it does atleast try and turn over but it wont even try do it. so thats why im thinking immobiiser has cut out the starter motor or ignition etc Quote
200sx-Starlet-Jay Posted November 22, 2009 Posted November 22, 2009 put it into gear, take hand break off, rock it backwards and fowards so the engine makes a rotation, put hand brake on, clutch in, and start her up mines done it 2 times now, everything seems normal, you then turn key it makes a click and then silent! if it aint battery, its more than likely the starter is jammed. giv it a shot and let me know!Jay Quote
Guest dominodon Posted November 22, 2009 Posted November 22, 2009 as the man said, Or sound like somethink is cutting off the engine- immobiiser Quote
Steve GT Posted November 22, 2009 Author Posted November 22, 2009 put it into gear, take hand break off, rock it backwards and fowards so the engine makes a rotation, put hand brake on, clutch in, and start her up mines done it 2 times now, everything seems normal, you then turn key it makes a click and then silent! if it aint battery, its more than likely the starter is jammed. giv it a shot and let me know!Jayyeh il give it a go mate but the thing that worries me is it doesnt even make that clicking sound theres nothing there apart from the fuel pump whining when i turn the key. il have a go at your method just to eliminate the possibility though dude and il let you know tomorrow lol Quote
200sx-Starlet-Jay Posted November 22, 2009 Posted November 22, 2009 yeh il give it a go mate but the thing that worries me is it doesnt even make that clicking sound theres nothing there apart from the fuel pump whining when i turn the key. il have a go at your method just to eliminate the possibility though dude and il let you know tomorrow lolsound. if it is the big fuses, they aint expensive so dont worry. uve gt fuel, which works on ignition. so ignition is sound, it will be a fuse to starter or somthing i would have thort :/Jay Quote
Steve GT Posted November 22, 2009 Author Posted November 22, 2009 yeh thats what im thinking but its finding the bloody things which seems to be impossible at the minute lol Quote
Guest dominodon Posted November 22, 2009 Posted November 22, 2009 defo the fuse or immobiiser nothing to worrie about it be good a gold soon Quote
Steve GT Posted November 22, 2009 Author Posted November 22, 2009 i hope so but if i cant find the problem im fooked lol Quote
chr15_7_t_ Posted November 23, 2009 Posted November 23, 2009 this hapend to me...would just click when i turnd the key. checked fuses they all seemd ok so i phoned a mate he came over and put a multi metr on the fuses and ther was one gone but i couldnt see it Quote
Steve GT Posted November 23, 2009 Author Posted November 23, 2009 is there any wiring diagrams for the starlet on here had a look cant find any Quote
chr15_7_t_ Posted November 23, 2009 Posted November 23, 2009 couldnt tel you that one thats y i just went through all the fuses lol one by one...takes some time but needed to be done Quote
Socks Posted November 24, 2009 Posted November 24, 2009 this is all sorted now it was indeed one of the 80amp slow blows at fault! Quote
Steve GT Posted November 24, 2009 Author Posted November 24, 2009 haha wow joined over a year agon and only just started posting lolmy good friend above is correct had the whole wiring loom out wires everywhere the night before last and no luck. got up the next morning and checked the 80 amp ALT fuse and it had indeed blown. new fuse and shes back out and running cheers for all the help anyway guys really happy I've got it sorted now lol Quote
