finnis Posted November 22, 2009 Share Posted November 22, 2009 hey guys new to jap cars. use to build my own engine parts wondered if this exhaust would fit off ebay,<H1 class=vi-is1-titleH1>OBX Racing Exhaust Headers 92-97 Toyota Paseo 1.5L 5EFEPart number is 380180174794please advise becoz was going to manufacturer 10 of my own in december to sell on.</H1> Quote Link to post Share on other sites
rob_bower Posted November 23, 2009 Share Posted November 23, 2009 yes the obx one will fit the only difference in is that the 5e block is 10mm taller than the 4e your current exhaust would later need modding to match up! And the lambda sensor may need lengthening! Quote Link to post Share on other sites
Jozinobi Posted November 23, 2009 Share Posted November 23, 2009 Bear in mind the obx will also be a bigger bore @2" and will need some minor grinding/shaving on the flange end to fit snugly.Its a good affordable 4-2-1 tho that makes a nice change to the usual drive after 4k revs or so. I loved mine.Joz Quote Link to post Share on other sites
rob_bower Posted November 23, 2009 Share Posted November 23, 2009 Jozinobi said: Bear in mind the obx will also be a bigger bore @2" and will need some minor grinding/shaving on the flange end to fit snugly.good point jozman id forgot that bit!!! Quote Link to post Share on other sites
