NightSpirit Posted August 22, 2006 Posted August 22, 2006 Before I get all dirty under the car, does the standard cat work similar to the one on the sw20 MR2 Turbo? As in, I remove it, smash out the honeycomb, put it back in...voila less restriction.Doing all the mods I can for cheap money for the other half to liven the car up a bit.
TRD_Starlet_08 Posted September 5, 2006 Posted September 5, 2006 but could you notice a differnce? noise, power? and what about an MOT?
Guest Enzo Posted September 5, 2006 Posted September 5, 2006 i noticed a masive difference on my 4efte after i gutted it,alot more mid range tourqe and a better top end
ecksjay Posted September 6, 2006 Posted September 6, 2006 Just remember to wear a mask - the dust can be rather unhealthy!what if you just chew on the insides of the cat? should that be alright?
glanzaV Posted September 6, 2006 Posted September 6, 2006 done mine today. sounds the same and goes a bit better, nothing special. Didnt notice much difference to be honest. worth doing though it's a little more responsive but thats bout it i found. ;)
DAN_GTT Posted September 6, 2006 Posted September 6, 2006 Theres not alot of point, you wont notice sod all difference, do a proper job and get a decat pipe ;)
ecksjay Posted September 6, 2006 Posted September 6, 2006 im sure it'll make a different at higher boost levels, we'll see when i get my blitz decat on eh ;)
TRD_Starlet_08 Posted September 11, 2006 Posted September 11, 2006 yea but honestly to a normal NA starbo would it make a difference, because the talk about it being alot more responsive on a TBo starlet but with out a Gt is there much point?
NightSpirit Posted September 11, 2006 Author Posted September 11, 2006 If you're on a budget...and want to get every last drop of poke from the car..and if you plan any other mods..I'd say it can never harm can it? Obviously on the turbo it restricts the turbo slightly...with the turbo it's not going to do as much good, but still it should be of some use if you have a spare few hours to kill
