yaristurbo Posted November 30, 2009 Posted November 30, 2009 Morning,Im in the final stages of coverting my yaris to a 1.3 turbo, im running a m4 motec and having trouble with the throttle position sensor not being copatible with the motec with it being a on/off switch. Does anyone having any advice on i know sensor that i can use and solve this headachecheers dan Quote
StarletRick Posted November 30, 2009 Posted November 30, 2009 is yours the blue yaris with the different front bumper? also, you need to get the throttle body from an automatic starlet turbo. the TPS is a 5v variable. thatll sort you right out. Quote
yaristurbo Posted November 30, 2009 Author Posted November 30, 2009 what will i nedd the auto throttble body for is it for size or the sensor mounting? And mine is silver with bronze ultralitesthe engines in it just small issues like the sensors and plugs Quote
yaristurbo Posted December 1, 2009 Author Posted December 1, 2009 still stuck on the on this one, those auto ones are like far and few, ive bin told nissan ones are same sort of idea? Quote
StarletRick Posted December 1, 2009 Posted December 1, 2009 the way the auto TPS attaches to the throttle body is completely different to the manual ones. youll need the whole throttle body and sensor to fit to the intake plenum. they are a direct fit and your best option. youll need to do some slight rewiring and its done. nissans do use 5v sensors. but again, youll need a nissan thorttle body to attach it to. then youll need to custom make something to get it to fit to the intake. Quote
yaristurbo Posted December 1, 2009 Author Posted December 1, 2009 ive just found a sensor from fensport, for a motec have you ever used one, having trouble finding a auto throttle body Quote
clarkie Posted December 1, 2009 Posted December 1, 2009 ive just found a sensor from fensport, for a motec have you ever used one, having trouble finding a auto throttle bodyjust broke an auto glanza so ive got what you need.. with loom and everything so ill chop the plugs off for you. Quote
yaristurbo Posted December 2, 2009 Author Posted December 2, 2009 just broke an auto glanza so ive got what you need.. with loom and everything so ill chop the plugs off for you.Sorry bud, sorted it out now just ordered a switch n plug from Fensport, found it was going to be easyier that way Quote
