Spuddy Posted August 23, 2006 Posted August 23, 2006 Does anyone know of a site i can go to to buy larger injectors for my EP-82Wots the best size upgrade to go for? 330cc? Wots the standard sized ones? Quote
lobotomy Posted August 23, 2006 Posted August 23, 2006 If you know what you're looking for then ebay -- but Greenline sells them Quote
DaMaGe Posted August 23, 2006 Posted August 23, 2006 Does anyone know of a site i can go to to buy larger injectors for my EP-82Wots the best size upgrade to go for? 330cc? Wots the standard sized ones?Depends what turbo and boost you want to run. With the CT9 its useless upgrading Quote
Spuddy Posted August 26, 2006 Author Posted August 26, 2006 Thanks guys.Is there advantage to upgradin em if i'm runnin the standard turbo? Quote
DaMaGe Posted August 30, 2006 Posted August 30, 2006 Thanks guys.Is there advantage to upgradin em if i'm runnin the standard turbo?Not worth it mate. Get yourself a Sard fuel reg instead mate. You'll be safe enough with that on your ct9 Quote
Spuddy Posted August 30, 2006 Author Posted August 30, 2006 Not worth it mate. Get yourself a Sard fuel reg instead mate. You'll be safe enough with that on your ct9Ordered a reg yesterday so hopefully get it before the weeks out.Are regulators easy to swap out? Will i notice any difference with one on? Suspect i'm running slightly lean atm so will be good for the engine to have one put on anyways i'm suspecting. Quote
DaMaGe Posted August 30, 2006 Posted August 30, 2006 Very easy to swap mate !!! As for difference not really as a turbo'd car runs faster when leaner hehe but better be safe than sorry Quote
