chr15_7_t_ Posted December 6, 2009 Posted December 6, 2009 tonight my pasenger side driveshaft came apart.. it came apart on the joint that is closet to the box..i am just wondering if this has hapend to anyone els and what they done to fix it..sort the old driveshaft? or get a new one?the old one dosnt look in bad shape but as i havnt had the boot apart before i dont no if ther should be a springle in the joint?if i need a new boot-kit whats rufly the prices and best place?if i need a new driveshaft?..whats 2nd hand prices or new prices if you can get?any help is good help thanks. Quote
micky boy Posted December 6, 2009 Posted December 6, 2009 was it the iner joint or outer? eather way they both have circlips the only way they can come out is if they have'nt been put in right so take your shaft out and have a look hope that helps Quote
chr15_7_t_ Posted December 6, 2009 Author Posted December 6, 2009 il be taking it out in about half an hour so il try get sum pics up see if i can get some advice:) Quote
Idrees Posted December 6, 2009 Posted December 6, 2009 Did it make any noise such as clicking noise when turning? If so your CV could be damaged and you'd need to replace it.Otherwise you can buy a new CV boot for about £6 and get it fitted for £10 or so.If you need an inner CV or a driveshaft, I have spares here. Quote
chr15_7_t_ Posted December 6, 2009 Author Posted December 6, 2009 just had a wee look and i adjusted my frst coment.i was meaning the joint closet to the box? Quote
Idrees Posted December 6, 2009 Posted December 6, 2009 Yeah thats the inner CV, sounds like the boot has come off mate so the grease may have leaked out. If it has then you will want to put new grease in because it could get damaged without it. Quote
micky boy Posted December 6, 2009 Posted December 6, 2009 that has a circlip to..it also has bearings.. get some pics up then we will have more of an idear Quote
micky boy Posted December 6, 2009 Posted December 6, 2009 it should be mate if you put you engine in this will be a pice off piss lolget some pics up anyway bud Quote
chr15_7_t_ Posted December 6, 2009 Author Posted December 6, 2009 ive done a engine cnversion before though, never done a cv boot lolwil do give me 10 mins Quote
chr15_7_t_ Posted December 6, 2009 Author Posted December 6, 2009 wellll its not salvagable*....the three bearigs on the shaft?..i have 2 now lol Quote
micky boy Posted December 6, 2009 Posted December 6, 2009 or god lol give idrees a shout he said he has one Quote
Vince#74-EP82 Posted December 19, 2009 Posted December 19, 2009 I came across this, also found it to be loosing a bearing from the inner boot on passenger side so changed the shaft.Guessing your sorted now but im curious to know if anyone else has seen this =/ Quote
