Engine Management Light Problem (with Video) Need Help :(
alright lads iam in need of some help.... when i went to start the car first time after fitting td04 kit it wouldnt start it would just tick over, iam not using a pcv valve so i blocked that with a bolt this is what i was getting:
http://s369.photobucket.com/albums/o...badstartup.flv
now after trying many things with no success i removed the bolt that blocked the pcv valve hose coming off the inlet and she started altho idle built up to 3k but once bolt was back it it idle was normal and no engine managment light... woo i was happy...for 10 seconds.
i was then getting this:
http://s369.photobucket.com/albums/o...2122009010.flv
you can see she was idling fine, temp was fine no management light until i started reving, this is were iam stuck does anyone know what coud be causing this? now my decat is only sealed using exhaust paste and is leaking (its only a temp measure as new exhaust going on next week) could this be causing the engine management light to go on? or is it something else any help greatly appreciated and repd.
oh and i tried a diagnosis test but couldnt understand it:
http://s369.photobucket.com/albums/o...t=diagtest.flv
any idea what that meant?
im on my laptop using a dongle so the viedeos will take too long to load. might still pop over 2moz if your not doing and we could take a look at it?
yeh mate that be good if you could, just give me a text in the morning ill be out tryin to sort it first thing have a few more bits and bobs to do aswell thanks bud.
