Hi there Guy's,
I have just installed Exedy Stage 1 Racing clutch,cause my release bearing was worn out and i thought that it was because of that i have this problem but now that i have replaced everything(Clutch Plate,Pressure Plate,Release bearing) i still have this problem.
My problem is when start driving at full torque(Just like starting in a race) i'll jump out like a rocket but when i need to shift to go to second gear it doesn't want to go in and all the rest are going fine could you guy's explain to me what my problem is and can i have some advice on how to fix this?
Car Specs:
Glanza 97 Specs
  1. Racing Airfilter
  2. Custom exhaust manifold & Downpipe
  3. Turbonetics Boost controller
  4. Fuel pressure regulator
  5. Supra fuel pump
  6. exedy stage 1 racing clutch
Thanks in advance
Tha Dragon
I'm sure there are problems with the clutch itself causing disengaging problems
I'm sure there was a post a few days back, someone else can give more info as I've not had this fault
Gary
Guest cheshireglanza
mine some time wont go in second and its had new clutch and box
Had a new clutch ~10k ago so defo not that my guess is
gearbox oil
shifter bushes
When i changed my replaced my clutch kit i drained the old oil and put new oil in.
What could be the problem then?
