silverglanza Posted December 22, 2009 Posted December 22, 2009 ive been havin a search on here not a direct ancer are they bolt on or you got to make brackets and could i buy a hoses to fit it or could i just use my glanza ones? Quote
ibz Posted December 22, 2009 Posted December 22, 2009 ive been havin a search on here not a direct ancer are they bolt on or you got to make brackets and could i buy a hoses to fit it or could i just use my glanza ones?got to make your own brackets.the standard glanza hoses will be fine mate Quote
silverglanza Posted December 22, 2009 Author Posted December 22, 2009 you got to take them to get welded ?or how you fixed it mate Quote
The_Notorious_C_A_T Posted December 22, 2009 Posted December 22, 2009 is it for a td04 or just want to run an uprated rad?As for mine I needed brackets made up, although normally you can move one accross by unbolting and reweld one of them. Depends how you want to mount it as I needed it mounted real low to clear my wastegate.and as Ibz said, he should know, he done it himself with my old rad Quote
juliogonza Posted December 22, 2009 Posted December 22, 2009 this is 2 way to make it your self is for tercel but i think it can help you http://board.tercelonline.com/viewthread.p...age=1#pid452625http://board.tercelonline.com/viewthread.p...age=1#pid453284 Quote
silverglanza Posted December 23, 2009 Author Posted December 23, 2009 cheers guys i just want a nice shiney rad no td04 or anything i think the madest ill be going is ct9 hybird lol Quote
silverglanza Posted December 23, 2009 Author Posted December 23, 2009 on that guys he had like a silver hook bracket on top any one got any of those floating about or they easy to make Quote
The_Notorious_C_A_T Posted December 23, 2009 Posted December 23, 2009 how mine is mounted:Bottom brackets are just like strips of metal but bent down if you get me with rubbers to protect from vibrations Quote
GT Phayer Posted December 25, 2009 Posted December 25, 2009 does the wiring from the civic fan plug striaght in to the starlet loom or does it have to be modified ??? Quote
