I drove one with a different set-up to any car i've drove before!
instead of pressing the button in & lifting,you have to pull the handbrake up & then pull the button type thing out & then it locks in place.
so.... are they all like this?
I could be wrong but i believe they are drifting handbrakes
that makes sense as you could pull the handbrake up to lock the wheels & then when your done just let go & it will just drop down.
Just to let you know they are not all like this ive had a couple of starlets and they both had handbrakes that work the 'normal' way
x2, sounds exactly like a drifty handbrake. Completly gay on a starbo :rolleyes:
i quite liked it ;) something different!
although i see your point in a way as it's not neccesary on a starlet.
thanks for your help :D
Pays to keep them well adjusted and look after:) i've no problems with mine
Damien
Thats because you have drums, so much better compared to discs :rolleyes:
