Carl. Posted December 30, 2009 Share Posted December 30, 2009 want to get timing belt changed on my glanza for peace of mind will the water pump need to be changed at the same time? and will i need to take it to a toyota specialist or is it easy enough for a mechanic at the nearest mot/service centre to do? (with it been an import)is there anything else i should be asking or know?thank you in advance carl Quote Link to post Share on other sites
ktl Posted December 30, 2009 Share Posted December 30, 2009 want to get timing belt changed on my glanza for peace of mind will the water pump need to be changed at the same time? and will i need to take it to a toyota specialist or is it easy enough for a mechanic at the nearest mot/service centre to do? (with it been an import)is there anything else i should be asking or know?thank you in advance carlyeh u might aswell get a new water pump. just for being on the safe side if it fail in the future Quote Link to post Share on other sites
Dan Evans Posted December 30, 2009 Share Posted December 30, 2009 if it looks fine you can do it without changing the pump, although while the belt is off, you might as well do it mate, there not expensive so if you do it as well you wont have to do it later on when the belt is back on. Quote Link to post Share on other sites
Carl. Posted December 30, 2009 Author Share Posted December 30, 2009 ok will do. thanks lads Quote Link to post Share on other sites
The_Notorious_C_A_T Posted December 30, 2009 Share Posted December 30, 2009 Change it while everything it out mate, only have to take things apart once then.I did a guide on how to change the timing belt. Easy enough bud. Just a bit fiddly.Oh things to know, one bolt on the engine mount is hidden, one bolt of the water pump housing is behind the engine mount and getting the crank pulley off without damaging it is also a bit awkward. Quote Link to post Share on other sites
Carl. Posted December 30, 2009 Author Share Posted December 30, 2009 would i need to change any other belts with the water pump then... like the alternator belt? Quote Link to post Share on other sites
The_Notorious_C_A_T Posted December 30, 2009 Share Posted December 30, 2009 alternator belt runs the water pump. So it's timing belt, alternator/water pump and power steering belt.Make sure you do the tensioner pulley and all that stuff as well. Quote Link to post Share on other sites
Dan Evans Posted December 30, 2009 Share Posted December 30, 2009 power steering belt wont need changing aslong as its not fraid etc, as it doesnt run off the water pump Quote Link to post Share on other sites
