woodyp Posted January 1, 2010 Posted January 1, 2010 who kno where the thermostat control is in a 98 reflet?? Quote
Idrees Posted January 1, 2010 Posted January 1, 2010 On the right side of the engine bay, under the dizzy block. There are two small 10mm nuts holding the cover on, take that off and theres the thermo. Hope that helps. Quote
woodyp Posted January 1, 2010 Author Posted January 1, 2010 On the right side of the engine bay, under the dizzy block. There are two small 10mm nuts holding the cover on, take that off and theres the thermo. Hope that helps.thanks idrees Quote
woodyp Posted January 1, 2010 Author Posted January 1, 2010 idrees is there any way of finding out if the inside is corroded..because the fan isnt chipping in to cool down the radiator but the ac works fine?? any suggestion Quote
Idrees Posted January 1, 2010 Posted January 1, 2010 I'm not too sure myself, replacements are cheap so if it hasn't been changed before I'd change it for the sake of having a fresh one. That's what I did with my Glanza just for peace of mind. Quote
Asad Posted January 1, 2010 Posted January 1, 2010 If it helps follow the bottom rad hose up, and to see if its corroded/been replaced check the colour of the coolant give you good indication of whats going on. Quote
BoostJunkie Posted January 1, 2010 Posted January 1, 2010 pull the thermostat out throw it in a cup of hot water see if it opens up. Also give the coolant temp sensor a look over is the temp gauge rising at all ?check the motor on the fan could be the motor has gone just run a feed direct from the battery to check that its ok. Quote
woodyp Posted January 2, 2010 Author Posted January 2, 2010 the fan is ok but the gauge goes straight up..i have to drive with the ac Quote
