Hey,
How easy is it to change the hinge on a door?
My drivers door is really loose needs a new hinge. Can I order one from Toyota? Would a UK starlet hinge fit? Is it a simple fix?
Cheers,
Oz
iirc there is a C clip on the pin to undo and some bolts thats about it......make sure you have some to help you hold the door etc
Hey man,
thanks for your reply.
Sounds pretty straight forward, I'll order some hinges from Toyota (£28 each plus vat) if I can't find any from breakers and get cracking.
Cheers,
Oz
