How is the gear gaiter replaced? Do you need to remove the plastic trim or can it be done without removing it? Also if the plastic trim needs to be removed, how is it removed?
When i took mine off i didnt have to remove the plastic, the Gear Gaiter should pop off as mine did, i pushed mine down in a corner and jobs a good one. Hope that helps a little.
Thanks mate...will keep you updated
