Ryno Posted September 4, 2006 Posted September 4, 2006 hiya guys, fitted my Braided lines, 3G Discs & Mintex Extreme Pads today, thought I would make a tutorial while I was at it. ;)okay a few things first, this is how I fitted my lines, discs & pads to my '93 EP82, if you feel I have left something out or feel you would like to add anything then please feel free to U2U me.secondly this was my first time fitting lines, discs & pads so bare with me lolokay to begin with, the tools I used for the job:14mm spanner10 " "12 " "17 " "4 " "Mole GripsG-ClampBrake Bleeding kitJackbit of woodAxle Standsmall brushWD40x2 Cable Tiessmall tubHere's a few pics of the parts,Braided Lines:3G 10 groove Discs:Mintex Extreme Pads:Right, now we are all tooled up and ready to start, here's a before pic:First off you need to jack the car up, this might seem a bit patronizing to some, but hey it's my tutorial ;)Make sure you loosen your wheel nuts before jacking.Here's how I jacked up my GT:note the bit of wood distributing the weight & alloy under the car incase something goes wrong.Here's where I put the Axle Stand:Now it's safe to take the wheel off.Braided LinesRight, onto the fitting of the lines, this is a pic of what the Std Lines look like.These are the two places that the Lines are connected.before you undo them, give them a spray with WD40 and a scrub with a small brush to get rid of any crap that might fall into the new lines. like so.Before you undo anything at this stage I put down some cardboard and got my small tub at the ready for any drips.start off by undoing the caliper bolt, this is with a 14mm spanner, clockwise.once this is off I clamped the line with the Mole Grips to stop the line dripping.I then put the washers on the new lines and gave then a little brake fluid for lube.attach this end to the end you have just taken off so that when the other end is taken off your ready to put it straight on with little mess.Now you need to remove the little Circlip Iâ??m pointing too,looks like this when off,then use the 17mm spanner to hold the line still and undo the other side with a 10mm spanner, clockwise.replace with new lead and tighten up.I found with the circlip that when I went to replace it, the gap on the new lines was a little larger, so I put a little kink in it as you'll see in the next pic for a snug fit.Lines are now done. Discs & PadsRight, onto the discs & pads, what I did first was to undo the top bolt with a 12mm spanner, clockwise.this then drops down so that you can remove the old pads, keeping hold of the metal shims,Then undo the x2 bolts that hold on the caliper with a 17mm spanner, clockwise.with this the old disc should just pull off, might need a little tap.then on with the new sexy discs.Next you need to push the piston back in on the caliper, for this I used a G-Clamp.then put the caliper back on.now put the metal shims onto the new pads, using the clips provided for the front pad. (note on the Mintex Extreme pads there's an adhesive strip to stick to these, so make sure you clean them first)(also note your hands shouldn't be covered in grease when handling the pads )Put the new pads in and reassemble,note, the grooves in these discs are directional and can go either way, decide before you fit them which way you'd like them, I changed my mind after fitting so they now look like this.(note: i used cable ties to secure the lines to the D2 metal bit to keep the lines clear because they wouldn't stay)then bleed the whole system, using either 4DOT or 5.1DOT.take a photo now replace Alloys(note: now follow the bedding in instructions provided with the Pads)Hope this helps a few of you guys. ;)Ryan
