silverglanza Posted January 13, 2010 Posted January 13, 2010 is it 15bhp off the mani and 15 off a decat to be gained or would it just be 15bhp gain off of both ive heard alot of myths whats the facts ? Quote
Idrees Posted January 13, 2010 Posted January 13, 2010 There's no actual fact to this tbh. Some people on mani and decat, stock boost make 140bhp or around that. Turn the boost up to see gains. Quote
riko666 Posted January 13, 2010 Posted January 13, 2010 Like the 0-60mph times, its all arbitrary - it depends on a lot of factors, and ultimately, you'd need to measure it. On such a small turbo and engine though, don't expect much more than 10bhp for the combination.. Quote
silverglanza Posted January 13, 2010 Author Posted January 13, 2010 Like the 0-60mph times, its all arbitrary - it depends on a lot of factors, and ultimately, you'd need to measure it. On such a small turbo and engine though, don't expect much more than 10bhp for the combination..ah right im guna put a full system on it and with my other mods relocated air filter rx-7 cooler maybe get a hybrid up the boost to a bar and get a fcd and a fpr and a new ecu remap? i was told to exspect anything from 165 up to 200 if using hybrid or is there anythin elese i could do if it wouldnt reach that much Quote
Sparky Posted January 13, 2010 Posted January 13, 2010 For a start you wont need a FPR/FCD if your thinking about getting it remapped with a piggy back.And power gains mostly rely on the boost your running on turbo cars.There will be a noticeable difference in spool up and mid range power with a mani and decat though. Quote
silverglanza Posted January 13, 2010 Author Posted January 13, 2010 thats what i was going to ask aswell when i put my full system on as the back pressure is gone and its runing freely will it still run ok or will i have to get a boost controler so it doesnt have boost creep ? also ive heared i have to get it mapped to make it run good Quote
Sparky Posted January 13, 2010 Posted January 13, 2010 Mine used to fuel cut really bad when I fitted a mani and decat.Bought an AVCR boost controller and it sorted it a bit but would cut every so often, all was fine when horrid fuel cut was removed and mapped for a bar Quote
silverglanza Posted January 13, 2010 Author Posted January 13, 2010 would i need a fcd untill i got my new ecu then ? Quote
Sparky Posted January 13, 2010 Posted January 13, 2010 NahYou gotta boost gauge?Instead of watching the revs I used to watch the boost gauge and apply or reduce the throttle accordingly. Quote
silverglanza Posted January 13, 2010 Author Posted January 13, 2010 to be honest bud i just want to plant it when i want and drive it normal cant be assed to mess around lol Quote
Sparky Posted January 13, 2010 Posted January 13, 2010 Be prepared to spend alot of money then.I was annoyed with fuel cut for months before I could get it mapped Quote
silverglanza Posted January 13, 2010 Author Posted January 13, 2010 where did you get it mapped and how much did it cost mate as i might just buy the bits and just put them on before it gets mapped Quote
enots Posted January 13, 2010 Posted January 13, 2010 mines running basically what your aiming for hybrid,gutted cat, ported mani etc but as i havent got a fpr or management yet im only runnning 0.6 bar of boost. but its still not shy its shifts to be fair so running a little less boost is always an option until you get management etc just a thought Quote
silverglanza Posted January 13, 2010 Author Posted January 13, 2010 cool i suppose you just connect it back up to the hi low boost button and keep it on low ? Quote
Sparky Posted January 13, 2010 Posted January 13, 2010 mapping was £400 and ecu was £300 so not cheap Quote
