needing some help with advice on what to do
ok ive posted in the wanted section for a replacement cylinder head as ive discovered a massive crack around the fourth exhaust port,
now some people are trying to pull the wool ove my eyes by quoting silly prices for a replacement cylinder head(as if im ignarent or somethin, purely ticks me off when that happens)
so im left no option but probably use the head off my 4efe sr,(if its identical which i hope)
my question is as i know the history of my sr (4efe)
will i still need to get it pressure tested and skimmed,
it would be good if someone knew a definate reliable answer on this as apart from saving me money it will also save me time in getting this minor problem sorted before the thrash,
any advice or views on the matter would be greatly apreaceated people
Get the face of the head checked out by an engineer and he will tell you mate. The fe and fte heads are the same for the 4e from memory
aparently the water chanels arnt the same so im on the hunt for an 4efte head again
thanx though gerrard
im not sure, i need to find the guy that did this to tell me what is different.
i clearly remember reading they wernt the same a few years back
it does fit and is similar but the guy had to modifiy the 4efe head somehow.
until someone has actualy done it im gona have to stick with the fte head,
i really dont want to take any chances, but as its panning out looks like ill be going to the thrash with the crack and the emanage not fitted,
abit of a shitter but as long as i beat you lobo then im jamin,
nuthin like abit of friendly competition bruv!!
Hah -- I don't think you'll have much problem dispensing with me mate!!
Was talking to Baz about maybe having a go against his to see the dif. We have nearly the same mods bar he's running a bit more boost
