DavidAshton Posted January 22, 2010 Posted January 22, 2010 As above,My intercooler pipe the bolts to my ct9 isn't perfectly straight so it boost leaks sometimes.So i thought i would use gasket sealant to get a pefect seal on the join.Checked out some stuff at halfords today and its rated upto 200 degrees. Will it be safe to use and not get too hot? ThanksDavid Quote
Nayls Posted January 22, 2010 Posted January 22, 2010 use silicone!!i even use it on exhausts!! 10x better than gun gum etc Quote
DavidAshton Posted January 22, 2010 Author Posted January 22, 2010 I think it is, well silicone gasket sealant. Im guessing the turbo outlet wont be as hot as an exhaust? So safe yeah? Quote
Nayls Posted January 23, 2010 Posted January 23, 2010 I think it is, well silicone gasket sealant. Im guessing the turbo outlet wont be as hot as an exhaust? So safe yeah?yeah,i think it will be fine mate. Quote
andy.i Posted January 23, 2010 Posted January 23, 2010 watch a blob doesnt fall down inside the turbo once you compress it Quote
