Gaz's GlanzaV Posted January 23, 2010 Share Posted January 23, 2010 Right, just in need of a quick question. Those of you guys that are running an RX7 top mount intercooler, how are you managing to trap the air onto the cooler ? As i`ve heard enzo stating that the rubber surround under the bonnet obviously is`nt big enough to cover the bigger RX7 cooler ? Any info... Quote Link to post Share on other sites
Sanchez Posted January 23, 2010 Share Posted January 23, 2010 Take the rubber surround off, will work fine mate. Quote Link to post Share on other sites
Raz Posted January 24, 2010 Share Posted January 24, 2010 Take the rubber surround off, will work fine mate.hey, i've still got the standard tmic, if i take the rubber off will that cause any issues? Quote Link to post Share on other sites
chriswoodfto Posted January 24, 2010 Share Posted January 24, 2010 you wana keep it on the standard as that channels the air straight onto and through the tmic. ive gota rx7 on mine, im gona do a step by step soon on modding the rubber seal so it fits the rx7 one nicely, keep your eyes open for the post. Quote Link to post Share on other sites
Gaz's GlanzaV Posted January 24, 2010 Author Share Posted January 24, 2010 Brilliant ! hav`nt got an RX7 cooler yet but i`m thinking about it if i make a move to try and get one, once i`ve found how to get round this little niggly issue Quote Link to post Share on other sites
durmz Posted January 24, 2010 Share Posted January 24, 2010 you wana keep it on the standard as that channels the air straight onto and through the tmic. ive gota rx7 on mine, im gona do a step by step soon on modding the rubber seal so it fits the rx7 one nicely, keep your eyes open for the post.kool, ide take a look at that.i use an rx7 cooler, dont use any of the old covers or seals, still alot better than the oem top mount Quote Link to post Share on other sites
chriswoodfto Posted January 24, 2010 Share Posted January 24, 2010 when i put my rx7 on, my boost went from 0.8 to 0.88 bar straight away, with out hsaving the air flow right yet.i just need a little bit longer rubber hose first to sit the i.c straight then im gona have a go at adapting the origional rubber seal tio fit the rx7 one. Quote Link to post Share on other sites
silverglanza Posted January 24, 2010 Share Posted January 24, 2010 i took the rubber seal off of mine and my rx-7 cooler is still really cold doesnt affect it one bit in my opinion Quote Link to post Share on other sites
chriswoodfto Posted January 24, 2010 Share Posted January 24, 2010 dont think itll neccasrilly affect it too much, but when toyota built the car they obveously put that rubber seal there for a reason so id like to adapt it to fit the rx7 jobbie. Quote Link to post Share on other sites
StarletCraigy Posted May 21, 2010 Share Posted May 21, 2010 personally i left the seal on mine, of course it won't cover the full width of the intercooler, but i figure you really need to direct and force the air onto it and through, not give it an alternative path, i'e down the sides. removing the rubber seal seems somewhat folly to me, the duct on top is not large enough and removing the seal will still not make it so, only adapting the seal is the way ahead , i'm intrigued to see to see this mod now. Quote Link to post Share on other sites
