nutnut Posted January 30, 2010 Posted January 30, 2010 When i got my glanza the interior light didn't work Thought the bulb had blown.No, the bulb was missing.Got a new bulb, went to put it in & it came on instantly.close the door & the light stays on switch it to off & the light stays on Mind baffled on this , Any ideas anyone . Quote
nutnut Posted January 30, 2010 Author Posted January 30, 2010 DamnWill pull it out tomorrow & have a go at fixing it.Might take the one out the corolla as they look identical.Cheers Kennedy Quote
4efte_ryan Posted January 30, 2010 Posted January 30, 2010 x2 sounds like a faulty switch or a door switch could be faulty Quote
Kennedy Posted January 30, 2010 Posted January 30, 2010 Yer the door push things could be faulty..does the light on your dash go off ok when you shut the door? Quote
nutnut Posted January 30, 2010 Author Posted January 30, 2010 Yes the dash light goes out when door is closed. Quote
kevink Posted February 26, 2010 Posted February 26, 2010 is the switch in the right position? you gotON OFF DOOR Quote
