paul w Posted September 13, 2006 Posted September 13, 2006 I got a bit of a problem at idle when the car is hot,revs sometimes drop right off and or stall totally,think it's the idle control valve.Where is it in the engine and anyone got one lying around for a 94 ep82? cheers folks Quote
Glanza_Ragger Posted September 13, 2006 Posted September 13, 2006 i "think" on the 82 its in the top right hand corner of the negine back, near the air filter box housing matey, ill try and find a picture of where mine is on my glanza ;) you got any error codes ? Quote
paul w Posted September 13, 2006 Author Posted September 13, 2006 Cheers mate, not sure how to do the error code check.How do you do that? It's only when the engine's hot,doin my head in it is! Quote
lobotomy Posted September 13, 2006 Posted September 13, 2006 There's a sticky in the tech section on how to check error codes Quote
paul w Posted September 14, 2006 Author Posted September 14, 2006 Righto i'll have a look thanks. Pissin it down now don't really fancy tinkering under the bonnet in the rain! ;) Quote
paul w Posted September 19, 2006 Author Posted September 19, 2006 I've had a look in the tech section and my fuse box don't look like the one in the pic.I've got a 94 quad light,is the one in the tech section for a galanza? Problem only seems to happen on a slight slope with a hot engine. Quote
