freak Posted February 5, 2010 Share Posted February 5, 2010 guys,is the master clucth slave and cylinder from a non turbo starlet same as a turbo starlet.reason am asking it is because ive recently bought a cap cluch but it seems am having trouble engaging the clutch to put in reverse it keeps making crunchin noise when shifting to reverse.note before was using a standard clutch and all was working fine.my car is a non turbo conerted to turbo..but used the master slave from the 4efe and the master cylinder from the 4efe...any help will be much apreciated Quote Link to post Share on other sites
starlet666 Posted February 5, 2010 Share Posted February 5, 2010 samne thing yes... i use a ep91 non turbo slave on mine.... just bleed ya lines and see how it is after that Quote Link to post Share on other sites
Idrees Posted February 10, 2010 Share Posted February 10, 2010 As above, it should be fine mate.I had a CAP clutch and it gave me problems, my mate has one in his Corolla and his gears started to crunch and damaged his gearbox. :surrender:Many others seem to have given good feedback on them though. Quote Link to post Share on other sites
