paul. Posted February 6, 2010 Posted February 6, 2010 how do i get my water bottle out?it must have got cracked in winter and needs fixing.thanks paul Quote
jimmy77 Posted February 7, 2010 Posted February 7, 2010 want a long reach ratchet 10mm and undo the 2 bolts mayb 3 bolts and jus pops out Quote
paul. Posted February 7, 2010 Author Posted February 7, 2010 Just jack it up and work from the bottom?Thanks Quote
rorenapier Posted February 7, 2010 Posted February 7, 2010 Which water bottle are you reffering to?Radiator over flow tank or the windscreen water bottle?And what car? Quote
paul. Posted February 7, 2010 Author Posted February 7, 2010 Which water bottle are you reffering to?Radiator over flow tank or the windscreen water bottle?And what car?ep 91 n/a sr 99windscreen washer yepthanks for reply Quote
Idrees Posted February 10, 2010 Posted February 10, 2010 You'll want to remove the bumper, or try and get behind it mate. When I was messing with mine the bumper off the car so it was easy, not sure how possible it is with the bumper attached to be honest. Quote
paul. Posted February 11, 2010 Author Posted February 11, 2010 Thanks for the repliesI got at it by taking off the inner arch!And the pump is bummed so I'm gona get a new one Quote
