chr15_7_t_ Posted February 13, 2010 Posted February 13, 2010 car idels about 900rpm but dosnt sit ther constantly..moves buy maybe 150-200rpm at the most so its going between 700-900rpm.the car spluters a wee bit while its doing this but nothing to bad.any help? Quote
Craig_N Posted February 13, 2010 Posted February 13, 2010 The exact thing happened to my in the S and all chris did was clean the idle control valve and its not done it since Quote
chr15_7_t_ Posted February 13, 2010 Author Posted February 13, 2010 was thinkin about that...done that on my old pug. just thought id get sum help Quote
Craig_N Posted February 13, 2010 Posted February 13, 2010 Just give it a clean and see if it solves it hopefully it does mate Quote
ollie ryan Posted February 13, 2010 Posted February 13, 2010 mines doing the same at the moment Quote
chriswoodfto Posted February 14, 2010 Posted February 14, 2010 me2, wers the idle control va;lve? mines worse when im messing with heaters and shit, have heard the earths on this car are crap tho. Quote
thunderpants Posted February 14, 2010 Posted February 14, 2010 sounds like the idle control valve alright. stand in front of the car and look at the engine. on the left hand side of the intake manifold you will see a wee grey thing connected to the side of it with two 10mm bolts. this is your idle control valve. it can mess about if dirt or water gets into it. you can buy a new one from toyota or get a second hand one off someone but a 2nd hand one might have the same problem. another thing yah can do is check for air leaks from your boost piping as my idle messed about crazy bad and idled at 3000 until i found my air pipe had blew off the actuator. Quote
chriswoodfto Posted February 14, 2010 Posted February 14, 2010 cool. mines really not that bad but ill give it a wipe, cant do any harm, does it only screw back on in one postion? or is it set at a position? just thinking back to when i cleaned my throttle postion sensor on my fto, was a bitch to get back in correct postion. Quote
thunderpants Posted February 14, 2010 Posted February 14, 2010 you really cant go wrong it just goes back on in the same position just be careful not to nip the o ring on the bit you insert into the intake manifold. i got a wee bit of wd40 just to lubricate the o ring when it was going back in. to get it off undo the 2 10mm bolts, take off the wee electrical connector andtake off the wee tube on the bottom of it and lift it out but youll see it when your doing it it is easy enough. Quote
