AaronW Posted February 28, 2010 Posted February 28, 2010 i bought one for the pulsar as it was silly cheap.as for any car,where is it recommended the other end of the negitive/earth be bolted to?list please, i.e where on the engine. aswell as the one on the chassisthanks Aaron Quote
nastyrash 2003 Posted March 24, 2010 Posted March 24, 2010 i bought one for the pulsar as it was silly cheap.as for any car,where is it recommended the other end of the negitive/earth be bolted to?list please, i.e where on the engine. aswell as the one on the chassisthanks Aaronhello thr mate, from the battery neg post to inlet manifold bolt or thr is a sensor eathing bank on the right side of the inlet mani, secured in by a 6mm bolt. thn you should have 1 from the manifold to the body - from the body back to the battery, the more earthing leads to the engine the better normaly use 2 my self one 8mm multicore wire to inlet (if alloy) manifold, 1 6mm wire to the gearbox, hope this helps fella. remember to leavel som slack in the length of wire as the engine does move a bit, also be very awair of the exhaust manifold as this getts very hot and will melt anything that it comes into contact with, also fans and drive belts. Quote
