its much easier to get parts like dizzy, rotor arms, sparkers from your local motor poarts shop. but being an import makes things harder!
What do the ep91 glanza engiens share with the n/a equiv!?
Basically the things i need to know are these:
Spark Plugs
Oil Filter - Im pretty sure this is same....
Dizzy
Rotor Arm
Cambelt & Tensioner Kit
Any help wud be perfect! ^_^
Matt.
spark plugs as standard are the same i think? when you begin to mod you need different heat ranges to suit (7,8,9 etc)
oil filter is the same
cambelt,tensioner, idler is the same
dizzy + rotor are are both different
standard air filter is the same
fuel filter is the same
brake pads/discs vary between the years
oil is a preference really (for the N/A 10w40 is perfect)
CV joints are different (inner outter spline count is different)
thermostat is the same
aux belts are the same (glanza has a different powersteering belt....use the N/A belt if you have removed AC)
water pump is the same
