Dan_SV Posted March 9, 2010 Share Posted March 9, 2010 Right I have recently bought a CT9 Hybrid off another member over on TGTT, and i am needing some information if anyone can help!I am getting a custom exhaust built and the guy thats doing it has suggested getting the turbos swapped over before he does the exhaust, as he isn't sure if the fitment will be the same when the exhaust is connected up?? I thought the Hybrid ct9 was a straight swap for the standard ct9 (obviously you need the corect mods) but other than that fitment is the same????If anyone can help that would be great. Quote Link to post Share on other sites
micky boy Posted March 9, 2010 Share Posted March 9, 2010 The ct9 and ct9 hybrid are the same mate just diffrent internals so it will be ok Quote Link to post Share on other sites
B11G KY Posted March 9, 2010 Share Posted March 9, 2010 Im sure its a straight fit mate! Quote Link to post Share on other sites
Dan_SV Posted March 9, 2010 Author Share Posted March 9, 2010 so everything else is the same on the exhaust side then??i'm was just a bit worried that i'd get the exhaust done then find the turbo wouldn't fit!! but if it is the same then will get the exhaust sorted asap!thanks micky mate thanks kyran Quote Link to post Share on other sites
ibz Posted March 9, 2010 Share Posted March 9, 2010 yeh the exhaust side will be the same mate Quote Link to post Share on other sites
Dan_SV Posted March 9, 2010 Author Share Posted March 9, 2010 thanks for the help guys, really appreciate it Quote Link to post Share on other sites
Guest Enzo Posted March 9, 2010 Share Posted March 9, 2010 the crew beat me to any type of reply there. thanx lads.@ Dan only the inlet on the compressor side is different, everything else bolts in the same place including actuater.watch when you put your decat gasket on that it does not foul the actuater flap so it gets full movement. you might need to trm bend the gasket once in place. Quote Link to post Share on other sites
Dan_SV Posted March 9, 2010 Author Share Posted March 9, 2010 thanks enzo, was gonna pm you but decided to put the thread up first!!well i should be getting the turbo fitted by Nick @ TD if all goes to plan so that shouldn't be an issue!thanks again for all your help guys, can't believe how quickly you managed to answer my question! its put my mind at rest anyways Quote Link to post Share on other sites
micky boy Posted March 9, 2010 Share Posted March 9, 2010 Not a problem Dan thats what we are here for mate Quote Link to post Share on other sites
