crazy gt Posted March 21, 2010 Posted March 21, 2010 hi can any one help need this sorted asap as had a crash in car i was using why my car off the road as above its a knocking/sweaking niose when going stright or turn right stops when turn left i have jacked up the car there is no movement left to right but there is movement up and down (if hold wheel from top and the bottom in and out movent) looked under the car got some one to move wheel lower joint seems to be fine you can see the disc and drive sharft move with the wheel any ideas Quote
Dean @RW-Developments Posted March 21, 2010 Posted March 21, 2010 id say posible the lower ball joint? is anythink bent? Quote
crazy gt Posted March 21, 2010 Author Posted March 21, 2010 id say posible the lower ball joint? is anythink bent?no nothing is bent I did think lower ball joint but it doesn't seem to move but wheel disc and shaft do Quote
GT Phayer Posted March 21, 2010 Posted March 21, 2010 get someone to hold there foot on the brake and then move the wheel.If the play goes its a wheel bearing mate, hope this helps Quote
crazy gt Posted March 21, 2010 Author Posted March 21, 2010 get someone to hold there foot on the brake and then move the wheel.If the play goes its a wheel bearing mate, hope this helpshi mate cheers top tip I will try this In a bit Quote
crazy gt Posted March 21, 2010 Author Posted March 21, 2010 let me know how it goes matewe do bud just waiting for someone to get home to put there foot on brack for me I might have a look for a bit of wood if there not back soon Quote
crazy gt Posted March 21, 2010 Author Posted March 21, 2010 let me know how it goes matehi bud you were spot on just did it with out brake on and its knocking and then with brake on could not get it to knock i will need new wheel bearing only thing is i need to get to work tommrow do you think it will be ok to drive or is not a good idea its only about 10-20 miles i need to do Quote
crazy gt Posted March 21, 2010 Author Posted March 21, 2010 if it was my car i wouldnt mateOk mate cheers for your help with this and again top tip thanks Quote
GT Phayer Posted March 21, 2010 Posted March 21, 2010 thats ok mate let me know how it all goes, always happy to help Quote
crazy gt Posted March 21, 2010 Author Posted March 21, 2010 thats ok mate let me know how it all goes, always happy to help will do bud cheers Quote
