Mo3 Posted March 31, 2010 Posted March 31, 2010 no i wish but gonna happen in 2 years time just wondering wat i wud have 2 do..im going to get the starlet gt engine (4efte) and smack it in you can pick up the front half of the car for around $2000 from this JDM place close to me so i think the front brakes of the GT i can put on the paseo..i think that would cost close to $600 and im not sure if i have to change the CV joints..also with the 4efte engine it comes with a topmount intercooler want to change that to a front mount..and in order to do that i think i would need a front body kit so it can fit..i think that is all id have to do im not sure please add things to the list Quote
Steve GT Posted April 13, 2010 Posted April 13, 2010 hasnt anyone on here got a 4efte paseo you can talk to? Quote
riko666 Posted April 13, 2010 Posted April 13, 2010 - you'll need to splice the wiring loom with the Paseos' one- front brakes are the same as the GT's- if you re-use your gearbox you won't need to swap driveshafts, use the GT's one and you "may" do- don't need a new front bumper if you shop properly for an intercooler Quote
Mo3 Posted April 14, 2010 Author Posted April 14, 2010 so transmission the same ? and new clutch Quote
riko666 Posted April 14, 2010 Posted April 14, 2010 No, but it can be used - the Starlet gearbox is far lower geared, and if yours is a C15X gearbox, has thicker gears too. You'll need the 4E-FTE clutch/flywheel Quote
Mo3 Posted April 14, 2010 Author Posted April 14, 2010 ye they sell the exedy 4e-fte cluthes for like 280 down here, riko have u done dis to your paseo? Quote
Mo3 Posted April 14, 2010 Author Posted April 14, 2010 so your saying if i buy a 4e-fte engine that comes with the turbos on it is all i need basically no need to swap the transmission? Quote
riko666 Posted April 14, 2010 Posted April 14, 2010 well if you're getting a front cut then yeah, you just need the engine, loom, ecu, a handy auto electrician, someone to put it into the Paseo, done Quote
Mo3 Posted April 14, 2010 Author Posted April 14, 2010 dats awsume dad can do all the labour of course when the time comes that is Quote
