i can sometimes change into neutral without pressing the clutch, and i dont need to press the clutch full to change gear
anyone know why?
Anup :p
not sure about the neutral thing, but i dont have to depress the clutch pedal all the way down to engage the clutch had a new clutch 30k ago
I had a new clutch fitted recently aswell, it didnt do this before
when you change gear you don't need to depress the clutch to pull the car out of gear into neutral. be careful wen pulling out of the gear, a little to far and CRUNCH!
you only need to fully depress the clutch to get into a gear. but i know you can can change gear without using the clutch, its extremely hard to do.
whoever fitted the clutch probably didn't adjust the pedal or something and left some play, is the pedal higher than before?
it was done by a toyota garage, and no it doesnt feel higher
