project82 Posted March 31, 2010 Posted March 31, 2010 does any 1 know what i would need to put a 5efe into my sr is it a straight swap?? Quote
Jozinobi Posted April 1, 2010 Posted April 1, 2010 Try searching '5efe' first mate.It has been covered a lot but basically its 98% plug and play.You use your original 4efe throttlebody and tps, original engine wiring, can use 4efe ecu or 5efe ecu prefably if your car will take it.There are also two sensors that need changing over, one is a water sensor and the other I can't recall. I've had the swap done in my car, now going 4EFTE.If you or someone is competent they will have no trouble with this swap. The hardest part is finding a decent 5efe engine that isn't burning oil and won't rape your pocket nowadays.Joz Quote
Guest Enzo Posted April 1, 2010 Posted April 1, 2010 me and gaz can do the convo for you, we stay local to you,once you find an engine get back to us,the conversion litteraly takes a few hours for me and gaz. Quote
ToyotaTech15 Posted April 1, 2010 Posted April 1, 2010 Defo no problem Geo, If interested get in touch mateGaz Quote
project82 Posted April 1, 2010 Author Posted April 1, 2010 nice 1 lads sounds mint ill let yazz ken what the crack is iff im going ahead with it Quote
