madmax_926 Posted April 5, 2010 Posted April 5, 2010 turbo is spooling nicely and can hear the recirculating dump valve its pretty loud but some times the car is not holding boost it increases up the revs but the power is not following sum times this happen sum times it dont the clutch aint slippin have replaced plugs + leads this sorted out misfire but i have not changed the dizzy + rotary arm what could be causing this (boost does not go past 0. need sum help im well confused Quote
Steve GT Posted April 13, 2010 Posted April 13, 2010 uprated actuator may solve your problem dudethe standard actuators are naff and are known for not holding boost very wellid invest in a nice HKS adjustable Quote
madmax_926 Posted April 28, 2010 Author Posted April 28, 2010 uprated actuator may solve your problem dudethe standard actuators are naff and are known for not holding boost very wellid invest in a nice HKS adjustable thanks steve exactly what i needed what a improvement car is running sweet as thanks hks was fitted today Quote
