bryz Posted April 10, 2010 Posted April 10, 2010 hey dude's. fitted a autobahn intercooler an a hks actuator. took it out for burn. Result, used to get full boost at about 3500rpm on standard tmic an actuator at this point my clutch was starting to slip, not bad but you could feel it. since the fmic an hks actuator went on, only get about 8 psi at 3500rpm an full boost at about 5000rpm an no slip. standard turbo,stock ecu an fueling. just breathing mods. Quote
jobo Posted April 10, 2010 Posted April 10, 2010 i think that you need to adjust the actuator a bit then it should reach full boost at 3500 at stay there all through the revs,heres a rough guide to what boost is at what length128mm = 0.5 bar123mm = 0.8 bar121mm = 1.0 barmesure it fron the end where the rod goes into the actuator to the middle of the pin at the other end of ithope it helps you sort it. Quote
bryz Posted April 11, 2010 Author Posted April 11, 2010 I'll double check later but i think it was set for 0.8 bar. had to turn it back half a turn cause a was hittin fuel cut. Quote
