andieep82 Posted April 26, 2010 Share Posted April 26, 2010 hi have recently had my engine forged and now when i start the vechile it idles high at around 1500 and stays like that for around 5 mins, could this be due to the automatic choke sensor?? need some advice cheers Quote Link to post Share on other sites
Kennedy Posted April 26, 2010 Share Posted April 26, 2010 Does it settle down once warm?If so it's fine, happens to alot of people :harhar: Quote Link to post Share on other sites
andieep82 Posted April 26, 2010 Author Share Posted April 26, 2010 Does it settle down once warm?If so it's fine, happens to alot of people :harhar:yes does settle down after a short period, is there no way of solving the problem though as want my engine running perfect or is it not a big deal Quote Link to post Share on other sites
Galliano Posted April 26, 2010 Share Posted April 26, 2010 Automatic choke? Quote Link to post Share on other sites
andy.i Posted April 26, 2010 Share Posted April 26, 2010 its cause the engines cold Quote Link to post Share on other sites
Raz Posted April 26, 2010 Share Posted April 26, 2010 i thought all starlets did that. Mine idles at about 1500-1700 and drops as it gets warmer and warmer, doubt it is anything to worry about. Quote Link to post Share on other sites
Guest ep82_girl Posted April 26, 2010 Share Posted April 26, 2010 i thought all starlets did that. Mine idles at about 1500-1700 and drops as it gets warmer and warmer, doubt it is anything to worry about.yeah same herexxx Quote Link to post Share on other sites
Asad Posted April 26, 2010 Share Posted April 26, 2010 Its the coolant temp sensor telling the rest of the electronic stuff that the cars cold and it needs to warm up....i.e idle high get the oil/water warmed for better fuel effeciency reduced engine wearby no means is it a bad thing totally normal :harhar: Quote Link to post Share on other sites
andieep82 Posted April 30, 2010 Author Share Posted April 30, 2010 ok thanks for your help will keep an eye on it still though asd i had an incling it could be the automatic choke!! but if its not a bad thing then i suppose not to worry cheers Quote Link to post Share on other sites
