Dan Evans Posted April 29, 2010 Posted April 29, 2010 is the rear oil crank seal the same as the 5EFE? I've compared it to the 4EFTE one and they look the same??? but the 4EFTE one fits snug, and the 5E is slightly loose, but very slightly??cheers Quote
Russleh Posted April 29, 2010 Posted April 29, 2010 if its loose id say its a slightly different size and goin by how everythin else like clutch n flywheel is diff on the engines id say different parts. just an assumption tho but if its loose its not gonna be stopping much oil comin out. Quote
riko666 Posted April 29, 2010 Posted April 29, 2010 I'd double-check the part numbers on Toyodiy Dan just to make sure Quote
