Right after being convinced the problem to the shite boost was down to the standard actuator i bought a HKS one and got it fitted
Got the old actuator off and yes it was fucked. it was so lose and crap it was unreal
got the new actuator on and set it like the standard one was, took it for a spin and was hitting 0.4 bar still
gave it 5 turns on the pin to shorten it and then it was o.45 ish so gave it another 10 turns and it was at 0.6 bar. now this seemed a lot of turns for such small gains and from what i remember from my black gt it only took a few turns to get the boost a bit higher
So I've taken some pictures (not brill quality as the digital cameras dead) but you can get the general gist of it. What i need from you lovely people is opinions from the pics if the actuators wound too far up for just 0.6 bar of boost cause where it is i think it should be running well more
Sorry for the poor quality :lol:
thanks
Wow mine isnt set that far in and im boosting @1bar.
Are you sure all your intercooler pipes are ok jubilee clips etc i know nut nut on here had the same problem not long ago only boosting 0.45 and he ended up haveing a small hole in his intercooler pipe work!!!
nah mate checked all the pipes all ok
luckily my front mount intercooler should be here any day now so that might help as i can put it together from scratch and make sure theres no leaks anywhere
there is a small crack in the mani but this wont affect it that much surely?
Hmmmm when i had my old glanza i got my self a HKS actuator and set it at 0.8bar then a few weeks later i took the heat shield off the mani and gess what i had a crack not to bad but enuf to lose boost!!!
So i got my self a standard mani and put it on and took the car for a spin and i hit fuel cut straight away so yeah if the mani is blowing get it sorted lol dont forget when it get super hot the crack will expand!!
true true
well hopefully getting it welded will help solve the problem
but would you reccoment turning the actuator back down then matey?
i only wanted to run about 0.75 bar anyway cause i hant got a mani, decat, cat back, FMIC or fuel pump yet. when i get all them its going up to 1 bar but as it is theres no way it will reach that high haha
