i have changed spark plugs 2 (bosch super 4s) also was trying 2 change manifold but gave up as couldn't get the last nut and now when idleing seems 2 be spluttering/missfiring drives okay tho any ideas ???
best off swaping all four as the firing wont be balanced it will be more effective on the 2 new ones while the old ones will not be. it will cause a unbalanced running and it the old plugs are that worn there will be excessivly un burnt fuel sat on the piston/valves. with the heat it might be clearing that fuel.
I reckon he's swapped em all, its just that its written in text talk...so i presume he means.."ive changed spark plugs TO bosch super4's...."
