offthatwall Posted May 27, 2010 Posted May 27, 2010 Im about to change my belts and this one looks tricky. whats the best way to go about this? Quote
micky boy Posted May 27, 2010 Posted May 27, 2010 There is a long bolt at the front of the power steering pump (THE TENCHNER) undo that abit then if you look at the left hand side of the pump you will see a 14mm nut on its own undo that then tap the pump down with the rubber end of an hammer and the belt should become slack hope that helps Quote
offthatwall Posted May 27, 2010 Author Posted May 27, 2010 alright, sounds easy enough.one last question; is the power steering belt also the AC belt?thanks. Quote
micky boy Posted May 27, 2010 Posted May 27, 2010 Yes mate the power steering belt is the A/C belt Quote
