so its no good to use then?
Well, it's ok or it wouldn't be sold, but there are better performing options. Plus you can't mix it with the non-silicon types, so you need to be sure which type your car has currently and if the brake system parts are ok with it.
If Toyota reckon you can use it then fine, but you might need to flush the old stuff out totally if it's dot 4 etc.
