can you re-use a pcv valve? need to switch rocker covers and cant be arsed spending more money on a new pcv valve at this moment in time
Thanks
Thanks
We remove them from most cars to be honest.
You can reuse it though, it just pulls out, i'd give it a clean as they soon get gunked up.
Just check its working by blowing through it each way afterwards.
Regards
Ricky
cheers ricky ill crack on with it this weekend then!
from experience you should order a new rubber grommit for it. they tend to harden up over time and break on removal. by all means reuse pcv but to stop you having an oh fuck moment pre order the grommit
