BoGlE Posted July 6, 2010 Posted July 6, 2010 hiim going to be buying a glanza pretty soon but because there imports the indicators are on the other side yeh..but because of a disability i cant use this setup. so my question is can you transfer a normal set of starlet stalks to a glanza so that the indicators are on the left? will they just fit straight on? i cant see any reason why you wouldnt be able to fit them straight on but i need to be sure.cheersjoe Quote
WallaceGlanza Posted July 10, 2010 Posted July 10, 2010 The starlet wiper stalk is on the same side as the glanza (they are the same car after all) like most jap cars are too, but you should be able to modify them to be on the left side with a little work. Quote
