Brake Discs Helppp
The only difference is the abs version comes with a lil metal ring , if you have abs you can tel by opening your bonnet and see if theres a few metal pipes running down the left hand side of the car, if you order abs and you dont have abs you can take the ring off easily enough and they will still work fine
thanks for that mate i ordered non abs as i no my car doesnt have it but i have fitted the brakes now and they are sweet as a nut it doesnt make a difference abs or not on the front but the rears are where you need to make sure you have the correct discs. i have also put them yellow stuff pads on and oh my god they are the best pads i have ever used from cold and even better when roasting hot. in all pretty impressed with the brakes i bought considering the whole kit with pads only came to £260 well chuffed
