ok well when i took apart my bro gt pistons and rods it was just a circlip and out came the pin but on my 4efe pisstons there isnt any circlips so im guessing i have to press them out is that correct? if so how do i do that without breaking the piston ?
need to know asap as i need to get my pistons on my scat rods to get my crank race balanced
thanks in advance
joel
There should be two small circlips next to the gudgeon pin, one on each side. If there isnt then you will have to press them out professionally! They will have to be heated up to be knocked out as they are not a 'floating' type piston
