Cali-BHC Posted July 30, 2010 Posted July 30, 2010 Basiclly there goosed.Thought it was the Turbo oil seals but turbo is spot on. So can only be valve stem seals.The problem i'm having is finding just the seals, i can find a full gasket set no probs, but i don't need everything. So can someone point me in the right direction.Also would you assume a forged motor will already be running a metal head gasket? If not best place to get one, i understand going bigger than 1.2mm i need ARP head studs too Cheers in advance guys and gals Quote
Guest cheshireglanza Posted July 30, 2010 Posted July 30, 2010 ^^ speak to nick at td he might be able sort you out with the bits you need i bought some arp head bolts off ebay for £100 still more on there Quote
5T4R7ET N/A Posted July 30, 2010 Posted July 30, 2010 if your looking for valve stem seals contact HYBRID on toyotagtturbo.com. he done group buys on them recently at a reasonable price, plus they are better quality than oem Quote
