First of all id like to know about putting a decal on my rocker cover... just a blitz sponsor decal, would it burn off or dry up?
and then:
and i need a retards guide to plumbing my external wastegate in lol, im lost :( it has 2 ports and i have some new vacume hose to fit.
not sure bout the sticker but with the external wastegate how are u controlling the boost? with an electronic boost controller, manual boost controller or are u just running it of the wastegate spring?
ha ha nvm the sticker then, and im using the spring atm, then i will be getting a controller soon as possible
ok just run a vacuum hose from the turbo vacuum port to the bottom port on the wastegate, just leave the top one.
