paul mc Posted August 2, 2010 Posted August 2, 2010 just need a bit of advice car was missing so had look found the king lead was damaged replaced the lead, still missing so changed plugs 2 bosch super 4 and seems 2 be even more noticeable also revs are up and down whiles idleing any thoughts ? Quote
nazzurro19 Posted August 2, 2010 Posted August 2, 2010 i had the same problem but i cudnt rev more then like 5.5k and ive changed the spark plugs and leads so hopefully when i fit em it will sort the problem, also check the plug gap and make sure its not more then 0.7 and also change the dizzy would be your next option Quote
paul mc Posted August 2, 2010 Author Posted August 2, 2010 thanks bud were would i get a new dizzy cap any idea? Quote
nazzurro19 Posted August 3, 2010 Posted August 3, 2010 The only one ive seen is ebay about 35 quid or try car placea like gsf eurocar parts LnR etc for a range called blueprint they are norm really good quite cheap or if it fails toyota Quote
philpott Posted August 3, 2010 Posted August 3, 2010 got my cap from toyota was just over £20 buddy had to wait 2 days but still is a denso one too if your doing that change your rotor arm too its only about 10boys from all parts. Quote
