Hi There guy's
I'ts been happing allot these days that i ride my car but after a couple of weeks i go to check my car to see if Engine oil and everything is ok, i get that my engine oil has dropped, i pour a bottle or half bottle after a couple of weeks again oil has dropped.
I checked if i got leakage but there's no sign of leakage or nasty slugde hanging or something.
Could one of u guy's help me with some info on what is going on with my Engine?
Best regards
Tha Dragon
is there blue smoke coming out of your exhaust??
if so, when does it do it...
from cold, but clears uup when warm? - valve stem oil seals
on boost? - turbo seals
on throttle off boost? - piston rings
if its burning it, those are your most likely candidates...
It does it when it's idle for a while and then it will give a little bit and then never again, it doesn't do it every time.
I thinks it's the valve stems to i guess i'll give it a check.
Yeah it's the second time i'm about to do it, now i know for the next time it's bad to buy aftermarket parts.
I liked your project thread, if i may for how much did u get the Blitz ECU?
